[GRASS-user] problem exporting maps using ps.map
Moritz Lennert
mlennert at club.worldonline.be
Mon Oct 30 05:09:35 EST 2006
Luca Penasa wrote:
> im trying to export a map using the ps.map command...
> im using grass 6.3 from cvs and the output is;
> WARNING: Data exists after final 'end' instruction!
here's the problem: you have an end somewhere where you probably
shouldn't and so it does not take into account any subsequent commands.
If you need more help you should post your ps.map instructions file.
Moritz
