[GRASS-user] problem exporting maps using ps.map
Moritz Lennert mlennert at club.worldonline.be
Mon Oct 30 07:24:52 EST 2006
Luca Penasa wrote:
> Moritz Lennert wrote:
>> Luca Penasa wrote:
>>> im trying to export a  map using the ps.map command...
>>> im using grass 6.3 from cvs and the output is;
>>> WARNING: Data exists after final 'end' instruction!
>> here's the problem: you have an end somewhere where you probably
>> shouldn't and so it does not take into account any subsequent commands.
>> If you need more help you should post your ps.map instructions file.
Moritz
>> Moritz
> i solve this deleting an 'end' at eof. but the problem is this:
> PS-PAINT: scale set to 1 : -168897.
> PS-PAINT: reading raster file <mappa in licheni> ...
> PS-PAINT: reading labels file <ibl in licheni> ...
> PS-PAINT: reading vector points file <sites_203 in licheni> ...
> PS-PAINT: reading text file ...
> *ERROR: PSmap: do_scale(): shouldn't happen *
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
