[GRASS-user] improved area calculations for raster maps.
Hamish
hamish_nospam at yahoo.com
Wed Sep 6 23:31:58 EDT 2006
Hamish:
> > Just saw this on slashgeo.org,
> > http://www.geovista.psu.edu/sites/geocomp99/Gc99/076/gc_076.htm
> > from a superficial look at the rotated squares and map of China I'd
> > say GRASS's v.to.rast & r.in.poly do a better job, but it would be
> > interesting for someone to run some trials and see how we stack up.
[probably the same actually,]
Dylan:
> I saw that too, but had difficulting replicating the tests, as I could
> not figure out how to rotate a raster generated with r.plane. recent
> traffic on this list suggests that tests could be done by r.to.vect
> -> v.transform ...
I just created a bunch of squares in a matlab* script & made them into
GRASS vectors (see attached; octave works in place of matlab).
See v.to.rast help page for tips on how/why lines, boundaries, and areas
are rasterized in slightly different ways.
Break this output into 9 different files before importing into 9
different vector maps! Then v.to.rast, r.report to get raster area.
e.g. 5 deg rotated:
v.in.ascii in=rot5.txt out=rot5 -n format=standard
# res of "6" units
g.region n=100 s=-100 w=-100 e=100 res=6
v.to.rast in=rot5 out=rot_5deg.6res use=cat
d.rast rot_5deg.6res
d.vect rot5 type=boundary
r.report map=rot_5deg.6res unit=me -qhn
area of box for this res: 9880.62443
(vs 10000 vector area)
same res, 45deg: 9733.70064
I find the paper's perimeter & resolution stuff a bit confusing to
replicate, and due to perimeter's fractal nature less interesting than
reported area.
Hamish
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20060907/5c3f18b7/rotating_sq.obj
B 5
45.4519477672043735 54.1675220419701873
-54.1675220419701873 45.4519477672043735
-45.4519477672043735 -54.1675220419701873
54.1675220419701873 -45.4519477672043735
C 1 1
35.220801 3.081421
1 5
B 5
40.5579787672638830 57.9227965339569266
-57.9227965339569266 40.5579787672638830
-40.5579787672638830 -57.9227965339569266
57.9227965339569266 -40.5579787672638830
C 1 1
34.818212 6.139390
1 10
B 5
35.3553390593273846 61.2372435695794479
-61.2372435695794479 35.3553390593273846
-35.3553390593273846 -61.2372435695794479
61.2372435695794479 -35.3553390593273846
C 1 1
34.150635 9.150635
1 15
B 5
29.8836238730119845 64.0856382055788600
-64.0856382055788600 29.8836238730119845
-29.8836238730119845 -64.0856382055788600
64.0856382055788600 -29.8836238730119845
C 1 1
33.223151 12.092238
1 20
B 5
24.1844762647975351 66.4463024388674626
-66.4463024388674626 24.1844762647975351
-24.1844762647975351 -66.4463024388674626
66.4463024388674626 -24.1844762647975351
C 1 1
32.042819 14.941812
1 25
B 5
18.3012701892219312 68.3012701892219383
-68.3012701892219383 18.3012701892219312
-18.3012701892219312 -68.3012701892219383
68.3012701892219383 -18.3012701892219312
C 1 1
30.618622 17.677670
1 30
B 5
12.2787803968972895 69.6364240320018979
-69.6364240320018979 12.2787803968972895
-12.2787803968972895 -69.6364240320018979
69.6364240320018979 -12.2787803968972895
C 1 1
28.961398 20.278989
1 35
B 5
6.1628416716219334 70.4416026402758746
-70.4416026402758746 6.1628416716219334
-6.1628416716219334 -70.4416026402758746
70.4416026402758746 -6.1628416716219334
C 1 1
27.083761 22.725974
1 40
B 5
0.0000000000000043 70.7106781186547551
-70.7106781186547551 0.0000000000000043
-0.0000000000000043 -70.7106781186547551
70.7106781186547551 -0.0000000000000043
C 1 1
25.000000 25.000000
1 45
