[GRASS-user] Presence/Absence error
Hamish
hamish_nospam at yahoo.com
Thu Sep 14 20:59:47 EDT 2006
Joel wrote:
> > Thanks guys! I had some vaque idea how to do it - but the v.to.ascii
> > command line is really fast - so just what I need.
> > However one problem is using v.to.rast:
> > http://static.flickr.com/93/242928408_189e335e04_o.png
> > This is result of:
> > create a raster map1 from v.to.rast
> > place nulls into map2 where map1 cells are not null (basically
> > subtracting the vector points from map2)
> > As you can see in the screenshot, some of the points and the raster
> > cells of map1 don't line up. Ignore the null cells at the bottom of
> > the map as it is near a coast line and have nothing to do with the
> > vector.
> > Any idea why this is? and how to get around it?
> Hi again, turns out I can't reproduce this error - thus it is most
> likely that occured from me doing something strange.
My guess is that the region bounds/resolution changed after the
v.to.rast type=points step, so the cells were being resampled on
display.
be sure to do:
g.region rast=target_map
before v.to.rast.
this also happens if your region is like: n=5000175 s=5000025 w=1000175
e=1000025 and your res=50. After zoom the region aligns to whole "00"
and all cells are resampled with 1/2 a cell error in both horiz and
vert.
Hamish
