[GRASS-user] Re: MS-Windows native GRASS
Huidae Cho grass4u at gmail.com
Sun Sep 17 17:41:12 EDT 2006
On Sun, Sep 17, 2006 at 11:33:32PM +0200, Anders Fahlén wrote:
> Hi,
> >That doesn't matter if the three files are in the same directory.  If
> >you're not sure where you should download them, just put them in
> >c:\download.  Please make sure you PC is ONLINE when running
> >inst_grass.bat.
> This is confirmed being the case.
> >You cannot just copy and run grass.bat without successful inst_grass.bat
> >since inst_grass.bat downloads/installs several libraries required for
> >winGRASS to run.
> It still doesn't work in my case. When I run the inst_grass.bat file I receive
> error messages:
> unzip: cannot find either /inst_grass/...
You will get this message for some *-dep.zip files since some of
GnuWin32 packages do not have *-dep.zip.  Does it say "cannot find
either /inst_grass/wget-1.10.2b.zip"?  In this case, please check if you
have c:\inst_grass\wget-1.10.2b.zip.  If not, go back to step 3 and
download this file.
Huidae
