[GRASS-user] "digitize menus" are not created
Maciej Sieczka tutey at o2.pl
Mon Sep 18 14:06:44 EDT 2006
temiz wrote:
> Hamish wrote:
>> temiz wrote:
>>> when I try to digitize a vector map, a different "digitize menus"  are
>>> not created.
>>> I tried to have it on both "debian GRASS 6.0.2 " and "compiled GRASS
>>> 6.0.2". But nothing happened. Older versions used to provide it.
>> does it work if at the GRASS console prompt you do:
>> d.mon x0
>> v.digit
>> if not, what sort of error do you see?
>> Hamish
> thank you
> when I enter:
> - d.mon x0
> - v.digit -n map=sil4 bgcmd="d.rast map=asp1"
> GRASS replies:
> "Map does not exist.
> New empty map created.
> 100%
> Segmentation fault"
True. There were v.digit bugs in 6.02, now solved:
http://intevation.de/rt/webrt?serial_num=4380
http://intevation.de/rt/webrt?serial_num=4604
It's a good practice to dig the bugtracker and list archive before
asking a question. You would know facts sooner if you did that :).
Maciek
