[GRASS-user] gdal and grass new problem from "is, but isn't"
series
Jarosław Jasiewicz
jarekj at amu.edu.pl
Thu Sep 21 04:02:17 EDT 2006
Huidae Cho napisał(a):
> On Thu, Sep 21, 2006 at 02:28:45AM -0500, Huidae Cho wrote:
>> On Thu, Sep 21, 2006 at 09:25:18AM +0200, Jarosław Jasiewicz wrote:
>>> Hi
>>> gdal 1.3.2 and 1.3.1 grass 6.3 cvs (newest), Kubuntu 6.06 and ubuntu 6.06 with
>>> added KDE
>>> after compilation of gdal over grass (without erros and warnings) when I try to
>>> run gdalinfo (or some other gdal utilities) message appears:
>>> gdalinfo: error while loading shared libraries: libgrass_vect.so: cannot open
>>> shared object file: No such file or directory
>>> of course libgrass_vect.so exist in /usr/local/grass6.3.cvs/lib/ as symlink to
>>> libgrass_vect.cvs.so
>> Check if your PATH includes /usr/local/grass6.3.cvs/lib.
> Did I say PATH? Sorry, it's LD_LIBRARY_PATH. If you cannot find the path,
> add the following lines to your ~/.profile or ~/.bash_profile:
> LD_LIBRARY_PATH="$LD_LIBRARY_PATH:/usr/local/grass6.3.cvs/lib"
> export LD_LIBRARY_PATH
> Huidae
>> Huidae
>>> regards
>>> Jarek
>>> grassuser mailing list
>>> grassuser at grass.itc.it
>>> http://grass.itc.it/mailman/listinfo/grassuser
unfortunatly not :(
