[GRASS-user] gdal and grass new problem from "is, but isn't"
series
Jarek Jasiewicz
jarekj at amu.edu.pl
Thu Sep 21 13:37:41 EDT 2006
Maciej Sieczka napisał(a):
> Jarosław Jasiewicz wrote:
>> Hi
>> gdal 1.3.2 and 1.3.1 grass 6.3 cvs (newest), Kubuntu 6.06 and ubuntu
>> 6.06 with added KDE
>> after compilation of gdal over grass (without erros and warnings) when I
>> try to run gdalinfo (or some other gdal utilities) message appears:
>> gdalinfo: error while loading shared libraries: libgrass_vect.so: cannot
>> open shared object file: No such file or directory
>> of course libgrass_vect.so exist in /usr/local/grass6.3.cvs/lib/ as
>> symlink to libgrass_vect.cvs.so
> I assume your gdal is installed under /usr/local.
> Try adding the following 2 lines:
> /usr/local/lib
> /usr/local/grass-6.3.cvs/lib
> to your /etc/ld.so.conf
> Then run ldconfig as root.
> /usr/local/lib is for gdal and other libs installed in your /usr/local,
> /usr/local/grass-6.3.cvs/lib is for grass 6.3.
> Maciek
Thanks, but I tried this
Jarek
