Hello, I have some point data for which the interpolation using the v.surf.rst does not give the best result. Is it possible to use somehow the kriging method? Is there an OS or other software running under linux or winxp making such interpolation and import it to grass? (Using the last cvs). Thank You in advance Tomas
