[GRASS-dev] Re: [GRASS-user] check vector geometry
Martin Landa landa.martin at gmail.com
Mon Sep 25 13:53:56 EDT 2006
? [1] ?, the patch attached.
Martin
[1] http://gama.fsv.cvut.cz/~landa/.../grass/g_region_pg.txt
2006/9/25, Maciej Sieczka <tutey at o2.pl>:
> Glynn Clements wrote:
> > Maciej Sieczka wrote:
> >> P.S.
> >> I'm wondering if flags should be exclusive or not in Grass modules, in
> >> general.
> > It depends upon the nature of the flags; flags should not be mutually
> > exclusive unless there is a reason.
> > Generally speaking, flags which select a particular mode of operation
> > may be mutually exclusive if it isn't useful (or practical) to perform
> > multiple distinct tasks in a single run (you can always run the
> > program once for each mode). OTOH, flags which modify specific aspects
> > (e.g. human-readable vs machine-readable output) should operate
> > independently of other flags.
> >> For example, I asked Jachym to make it possible to his new '-t' flag
> >> not to be excluded if used together with '-g', and it works. No matter
> >> what flag seqeunce, if both are used, first goes the '-g' output, then
> >> '-t'. But maybe I asked him for a wrong thing, maybe flags should be
> >> exclusive? Or if they should be not exclusive, should the order they
> >> are called metter? Eg. should '-tg' and '-gt' output in the same sequence?
> > Flags are either present or absent; a module cannot determine the
> > order in which flags are specified.
> > If you want various items of data output in a specific order, use an
> > option with multiple values, e.g. output=region,topology vs
> > output=topology,region.
> >> Other modules (eg. g.region and r.info) don't allow for using many
> >> flags at the same time, and they have some hierachy in excluding them,
> >> but I can't find a pattern for that (is there one?).
> >> Moreover, I found a strange thing about g.region. Try this:
> >> $ g.region -e
> >> region north-south extent: 270.000000
> >> region east-west extent: 300.000000
> >> $ g.region -g
> >> n=4916070
> >> s=4915800
> >> w=602940
> >> e=603240
> >> nsres=30
> >> ewres=30
> >> rows=9
> >> cols=10
> >> BUT A COMBINATION OF BOTH GIVES NEITHER OF THE ABOVE:
> >> $ g.region -eg
> >> ns_extent=270.000000
> >> ew_extent=300.000000
> >> The region extent is printed, like if -e alone was used, but instead of
> >> "region north-south extent" we get "ns_extent". Same thing, but
> >> different wording.
> > That makes sense. The -e flag displays the extents, while -g selects a
> > machine-readable format. Using both should display the extents in a
> Indeed it makes much sense, I get it. Hmm, but then -gc, -gl should
> also output in a machine-readable format - but they don't, they still
> print like if -c, -l was used alone.
> Moreover, g.region description says: "-g Print the current region
> (shell script style)". It doesn't mention the fact it can be combined
> with other flags to make them print in shell script style - it only
> mentions the region.
> Given these, how should g.region be fixed then?
> I suppose that -g alone should not work at all. Only when combined with
> -p,-e,-c,-l it should print their machine-readable version. That would
> make things clear and consistent. Of course not a plan for Grass 6.
> Grass 7?
> > Note that -g is essentially shorthand for -pg; any option which
> > selects an output format implies -p unless some other option is given.
> That's good to know, but it is not the way it is explained in Description.
> > It's arguable that -pe should display the extents as well as the other
> > region parameters, and -peg should do likewise but using
> I second that.
> > Similarly, -lg should display lat/lon boundaries in shell format.
> Ditto.
> Maciek
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
Martin Landa <landa.martin at gmail.com> * http://gama.fsv.cvut.cz/~landa *
Type: application/x-gzip
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20060925/aa2ec381/g_region_pg.diff.gz
