[GRASS-user] Help combining raster and vector data into single
	raster image
    Romy Schneider
    romy at tacc.utexas.edu
    Mon Sep 25 15:25:15 EDT 2006
I am currently trying to take a raster map and a vector map and
combine them to produce a raster (image) map.  I am running GRASS
6.1.0 on an Intel Mac and have tried several different avenues, none
to any success.  If anyone has any successful experience with any of
the following methods, I would greatly appreciate any help you could
provide.
1.  First tried displaying everything in the "Map Display" window,
saving this image as a TIFF, JPG, BMP, and/or a PPM, and then
importing this image using r.in.gdal.
   In every case, the output image looks fine, but r.in.gdal imports
the three bands (red, green, blue or 1, 2, 3) as empty files.  At
least, when I display the files, there is nothing there.  I tried
combining the three bands into a single RGB raster using r.composite,
and also tried overriding the projection on import in case there was
a problem with that, but neither trick worked.  Is there something I
am missing here?
2.  Also tried using the regular display monitor with the PNG driver
to save a PNG file.  Similar problem, as I can produce the png file,
but when I import this into Grass, it again is an empty file.     I
would like to use the CELL driver (per Grass 5 documentation), but
this feature must have been removed from Grass 6, because it is not
listed as a valid display monitor with d.mon -l and when I try the
command "d.mon start=CELL" it says there is no such monitor as 'CELL'.
3.  I also tried to get around the apparent r.in.gdal problem by
using gdal_translate to translate the various image files (TIFF, JPG,
etc) into an ArcInfo ASCII grid and then import this into Grass using
r.in.arc.  While gdal_translate writes the Arcinfo grid sucessfully,
trying to import this file in grass using r.in.arc results in the
following error:
r.in.arc: ** errors detected in header section **
   illegal line in header
   dx           1.000000000000
   "cellsize" field missing from header
   "nodata_value" field missing from header
ERROR: Can't get cell header
Does anyone what I am doing wrong in any of these methods (it is very
likely I am missing something, I've only been using grass for a
couple of weeks)?  Or have any tips on how to accomplish what I want
to produce?
Thanks in advance for any advice.
Romy
