[GRASS-dev] RE: [GRASS-user] Error importing DMS into standar
dformat usingv. in.ascii
Patton, Eric
epatton at nrcan.gc.ca
Wed Sep 27 11:43:31 EDT 2006
Again, it fails even if W and N are omitted:
echo "66.5|44.25" | v.in.ascii -n output=DMS_test format=standard --o
Error reading ascii file:
66.5|44.25
Building topology ...
0 primitives registered
0 areas built
0 isles built
Attaching islands:
Attaching centroids: Topology was built.
Number of nodes : 0
Number of primitives: 0
Number of points : 0
Number of lines : 0
Number of boundaries: 0
Number of centroids : 0
Number of areas : 0
Number of isles : 0
I tried reversing Long and Lat, but get the same error. Interestingly, the
"Error reading ascii file" line disappears if I run the same command without
the -n flag, but still fails:
echo "66.5|44.25" | v.in.ascii output=DMS_test format=standard --o
0 areas built
0 isles built
Attaching islands:
Number of nodes : 0
Number of lines : 0
Number of areas : 0
Number of isles : 0
-----Original Message-----
To: ''grassuser at grass.itc.it' '; ''grass-dev at grass.itc.it' '
Sent: 9/27/2006 11:29 AM
Subject: Re: [GRASS-dev] RE: [GRASS-user] Error importing DMS into
standardformat usingv. in.ascii
I think that decimal degree go without W and N since
the minus is used for West/South.
Markus
On Wed, Sep 27, 2006 at 12:18:54PM -0300, Patton, Eric wrote:
> Trying again after converting DMS to deciaml degrees:
> echo "L 4 1
> 66.5W|44.25N
> 66.0W|44.25N
> 66.0W|44.0N
> 66.5W|44.0N
> 1 1 " | v.in.ascii -n output=DMS_test format=standard --o
> 66.5W|44.25N
> 0 areas built
> 0 isles built
> Attaching islands:
> Number of nodes : 0
> Number of lines : 0
> Number of areas : 0
> Number of isles : 0
> The above command also fails if the coodinates are given to 6 decimals
> places, which probably doesn't even matter.
> ~ Eric.
