[GRASS-dev] RE: [GRASS-user] Error importing DMS into standar
	dformat usingv. in.ascii
    Patton, Eric
    epatton at nrcan.gc.ca
    Wed Sep 27 12:47:39 EDT 2006
The advantage with importing 'standard' types (once I can memorize how to do
it) is that lines and boundaries automatically get digitized and snapped to
the vertices, which is nice when you're trying to create precise map
surrounds (which is what I'm doing). I might throw a few extra hints in the
man page based on my experiences getting it to work today.
~ Eric.
-----Original Message-----
To: Hamish
Cc: Patton, Eric; grassuser at grass.itc.it
Sent: 9/27/2006 12:30 PM
Subject: Re: [GRASS-dev] RE: [GRASS-user] Error importing DMS into standar
I found the easiest input method is to use the spreadsheet of your
choice and generate a CSV file. v.in.ascii is quite particular about
extraneous characters.
Hamish wrote:
> Patton, Eric wrote:
>> Again, it fails even if W and N are omitted:
>> echo "66.5|44.25" | v.in.ascii -n output=DMS_test format=standard --o
> format=standard wants
> L n
>  x1 y1 [z1]
>  xN yN [zN]
> so " " not "|" and you need to start with the "L n" line.
> Hamish
> grassuser mailing list
> http://grass.itc.it/mailman/listinfo/grassuser
