[GRASS-user] Local variables
Thu Sep 28 11:08:54 EDT 2006
Michael Perdue wrote:
> Just a quick question. Are the parameters of a region available as
> variables to be called from a shell script or do I need to use
> g.region to assign them to variables from within the script.
You need to run g.region, like:
	eval `g.region -g`
That will set the following variables:
	n s w e nsres ewres rows cols
