[GRASS-user] GRASS 6.2.0beta3 builds but gaves 2 errors
Jaros?aw Jasiewicz
jarekj at amu.edu.pl
Fri Sep 29 04:42:10 EDT 2006
Eduardo Patto Kanegae napisa?(a):
> Hi,
> I'm on suse 10.1, and already build my grass 6.2b3 using:
> ./configure --enable-w11 --with-cxx --with-jpeg --with-tiff --with-png
> --with-tcltk --with-postgres
> --with-postgres-includes=/usr/include/pgsql --with-mysql
> --with-mysql-includes=/usr/include/mysql --with-sqlite --with-odbc
> --with-odbc-includes=/usr/local/src/epk/unixODBC- 2.2.11/include
> --with-fftw --with-fftw-libs=/usr/lib --with-freetype
> --with-freetype-includes=/usr/include/freetype2 --with-readline
> --with-curses --with-python --with-gdal=/usr/local/bin/gdal-config
> --with-zlib-libs=/lib --with-proj-libs=/usr --with-x
> --disable-largefile --without-opengl 2>&1 | tee configure.log
> . and this gave the following:
> GRASS is now configured for: i686-pc-linux-gnu
> Source directory: /usr/local/src/epk/grass-6.2.0beta3
> Build directory: /usr/local/src/epk/grass- 6.2.0beta3
> Installation directory: /usr/local/grass-6.2.0beta3
> Startup script in directory: ${exec_prefix}/bin
> C compiler: gcc -g -O2 -D__W98__
> C++ compiler: c++ -g -O2
> FORTRAN compiler:
> Building shared libraries: yes
> 64bit support: no
> OpenGL platform: none
> NVIZ: no
> BLAS support: no
> C++ support: yes
> DWG support: no
> FFMPEG support: no
> FFTW support: yes
> FreeType support: yes
> GDAL support: yes
> GLw support: no
> JPEG support: yes
> LAPACK support: no
> Large File Support (LFS): no
> Motif support: no
> MySQL support: yes
> NLS support: no
> ODBC support: yes
> OGR support: yes
> OpenGL support: no
> PNG support: yes
> PostgreSQL support: yes
> Python support: yes
> Readline support: yes
> SQLite support: yes
> Tcl/Tk support: yes
> TIFF support: yes
> X11 support: yes
> and then, after make ,
> I can run grass using -text ou even gui interface, but
> the curious fact was that at the end of make appears:
> Errors in:
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER
> /usr/local/src/epk/grass- 6.2.0beta3/display/d.mon/pgms
> then I "cd" and type "make" to each of these folders and got the
> errors shown at the attached files.
> what these errors mean?
> regards,
> http://www.webmapit.com.br
> gcc -L/usr/local/src/epk/grass-6.2.0beta3/dist.i686-pc-linux-gnu/lib -Wl,--export-dynamic -Wl,-rpath-link,/usr/local/src/epk/grass-6.2.0beta3/dist.i686-pc-linux-gnu/lib -o /usr/local/src/epk/grass-6.2.0beta3/dist.i686-pc-linux-gnu/driver/XDRIVER -L/usr/local/src/epk/grass-6.2.0beta3/dist.i686-pc-linux-gnu/lib OBJ.i686-pc-linux-gnu/Box.o OBJ.i686-pc-linux-gnu/Can_do.o OBJ.i686-pc-linux-gnu/Client.o OBJ.i686-pc-linux-gnu/Color_table.o OBJ.i686-pc-linux-gnu/Color.o OBJ.i686-pc-linux-gnu/Draw_bitmap.o OBJ.i686-pc-linux-gnu/Draw_line.o OBJ.i686-pc-linux-gnu/Draw_point.o OBJ.i686-pc-linux-gnu/Get_w_box.o OBJ.i686-pc-linux-gnu/Get_w_line.o OBJ.i686-pc-linux-gnu/Get_w_pointer.o OBJ.i686-pc-linux-gnu/Graph_close.o OBJ.i686-pc-linux-gnu/Graph_set.o OBJ.i686-pc-linux-gnu/Line_width.o OBJ.i686-pc-linux-gnu/Panel.o OBJ.i686-pc-linux-gnu/Polydots.o OBJ.i686-pc-linux-gnu/Polygon.o OBJ.i686-pc-linux-gnu/Polyline.o OBJ.i686-pc-linux-gnu/Raster.o OBJ.i686-pc-linux-gnu/Raster_RGB.o OBJ.i686-pc-linux-gnu/Respond.o OBJ.i686-pc-linux-gnu/Serve_Xevent.o OBJ.i686-pc-linux-gnu/Work.o OBJ.i686-pc-linux-gnu/alloc.o OBJ.i686-pc-linux-gnu/main.o -lgrass_driver -lgrass_gis -lgrass_datetime -L/lib -lz -lfreetype -lgrass_gis -lgrass_datetime -L/lib -lz -lfreetype -L -lX11 -lm -L/lib -lz
> OBJ.i686-pc-linux-gnu/Box.o: In function `XD_Box_abs':
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Box.c:20: undefined reference to `XFillRectangle'
> OBJ.i686-pc-linux-gnu/Client.o: In function `set_size':
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Client.c:20: undefined reference to `XGetWindowAttributes'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Client.c:34: undefined reference to `XSetWMNormalHints'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Client.c:35: undefined reference to `XFlush'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Client.c:18: undefined reference to `XAllocSizeHints'
> OBJ.i686-pc-linux-gnu/Color_table.o: In function `XD_Color_table_fixed':
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Color_table.c:407: undefined reference to `XSetWindowColormap'
> OBJ.i686-pc-linux-gnu/Color_table.o: In function `XD_Color_table_float':
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Color_table.c:379: undefined reference to `XSetWindowColormap'
> OBJ.i686-pc-linux-gnu/Color_table.o: In function `XD_reset_color':
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Color_table.c:364: undefined reference to `XStoreColor'
> OBJ.i686-pc-linux-gnu/Color_table.o: In function `try_get_grays':
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Color_table.c:181: undefined reference to `XAllocColor'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Color_table.c:183: undefined reference to `XFreeColors'
> OBJ.i686-pc-linux-gnu/Color_table.o: In function `init_color_table':
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Color_table.c:283: undefined reference to `XFreeColormap'
> OBJ.i686-pc-linux-gnu/Color_table.o: In function `ramp_colormap':
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Color_table.c:197: undefined reference to `XCreateColormap'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Color_table.c:212: undefined reference to `XStoreColor'
> OBJ.i686-pc-linux-gnu/Color_table.o: In function `try_get_colors':
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Color_table.c:150: undefined reference to `XAllocColor'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Color_table.c:152: undefined reference to `XFreeColors'
> OBJ.i686-pc-linux-gnu/Color.o: In function `XD_color':
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Color.c:32: undefined reference to `XSetForeground'
> OBJ.i686-pc-linux-gnu/Draw_bitmap.o: In function `XD_draw_bitmap':
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Draw_bitmap.c:18: undefined reference to `XGetWindowAttributes'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Draw_bitmap.c:37: undefined reference to `XCreateImage'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Draw_bitmap.c:44: undefined reference to `XPutImage'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Draw_bitmap.c:46: undefined reference to `XSetForeground'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Draw_bitmap.c:47: undefined reference to `XPutImage'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Draw_bitmap.c:28: undefined reference to `XCreateGC'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Draw_bitmap.c:32: undefined reference to `XCreateGC'
> OBJ.i686-pc-linux-gnu/Draw_line.o: In function `XD_draw_line':
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Draw_line.c:6: undefined reference to `XDrawLine'
> OBJ.i686-pc-linux-gnu/Draw_point.o: In function `XD_draw_point':
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Draw_point.c:6: undefined reference to `XDrawPoint'
> OBJ.i686-pc-linux-gnu/Get_w_box.o: In function `XD_Get_location_with_box':
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Get_w_box.c:49: undefined reference to `XDefineCursor'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Get_w_box.c:57: undefined reference to `XCreateGC'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Get_w_box.c:62: undefined reference to `XSelectInput'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Get_w_box.c:135: undefined reference to `XUndefineCursor'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Get_w_box.c:136: undefined reference to `XSelectInput'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Get_w_box.c:137: undefined reference to `XFreeGC'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Get_w_box.c:133: undefined reference to `XDrawRectangle'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Get_w_box.c:113: undefined reference to `XDrawRectangle'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Get_w_box.c:92: undefined reference to `XDrawRectangle'
> OBJ.i686-pc-linux-gnu/Get_w_line.o: In function `XD_Get_location_with_line':
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Get_w_line.c:48: undefined reference to `XDefineCursor'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Get_w_line.c:56: undefined reference to `XCreateGC'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Get_w_line.c:61: undefined reference to `XSelectInput'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Get_w_line.c:107: undefined reference to `XUndefineCursor'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Get_w_line.c:108: undefined reference to `XSelectInput'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Get_w_line.c:109: undefined reference to `XFreeGC'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Get_w_line.c:105: undefined reference to `XDrawLine'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Get_w_line.c:91: undefined reference to `XDrawLine'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Get_w_line.c:90: undefined reference to `XDrawLine'
> OBJ.i686-pc-linux-gnu/Get_w_pointer.o: In function `XD_Get_location_with_pointer':
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Get_w_pointer.c:57: undefined reference to `XDefineCursor'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Get_w_pointer.c:58: undefined reference to `XSelectInput'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Get_w_pointer.c:93: undefined reference to `XUndefineCursor'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Get_w_pointer.c:94: undefined reference to `XSelectInput'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Get_w_pointer.c:42: undefined reference to `XDefineCursor'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Get_w_pointer.c:43: undefined reference to `XGetInputFocus'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Get_w_pointer.c:53: undefined reference to `XUndefineCursor'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Get_w_pointer.c:45: undefined reference to `XQueryPointer'
> OBJ.i686-pc-linux-gnu/Graph_close.o: In function `XD_Graph_close':
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Graph_close.c:8: undefined reference to `XFreePixmap'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Graph_close.c:9: undefined reference to `XDestroyWindow'
> OBJ.i686-pc-linux-gnu/Graph_set.o: In function `XD_Graph_set':
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Graph_set.c:318: undefined reference to `XOpenDisplay'
> OBJ.i686-pc-linux-gnu/Graph_set.o: In function `create_window':
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Graph_set.c:201: undefined reference to `XAllocSizeHints'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Graph_set.c:212: undefined reference to `XCreateWindow'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Graph_set.c:224: undefined reference to `XAllocWMHints'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Graph_set.c:225: undefined reference to `XCreateBitmapFromData'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Graph_set.c:229: undefined reference to `XAllocClassHint'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Graph_set.c:246: undefined reference to `XSetWMProperties'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Graph_set.c:250: undefined reference to `XInternAtom'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Graph_set.c:251: undefined reference to `XSetWMProtocols'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Graph_set.c:254: undefined reference to `XMapWindow'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Graph_set.c:334: undefined reference to `XCreateColormap'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Graph_set.c:343: undefined reference to `XSetWindowColormap'
> OBJ.i686-pc-linux-gnu/Graph_set.o: In function `create_cross_cursor':
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Graph_set.c:295: undefined reference to `XQueryColor'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Graph_set.c:298: undefined reference to `XQueryColor'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Graph_set.c:300: undefined reference to `XCreateBitmapFromData'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Graph_set.c:301: undefined reference to `XCreateBitmapFromData'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Graph_set.c:303: undefined reference to `XCreatePixmapCursor'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Graph_set.c:365: undefined reference to `XCreateFontCursor'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Graph_set.c:368: undefined reference to `XCreateGC'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Graph_set.c:373: undefined reference to `XGetWindowAttributes'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Graph_set.c:381: undefined reference to `XCreatePixmap'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Graph_set.c:382: undefined reference to `XSetWindowBackgroundPixmap'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Graph_set.c:383: undefined reference to `XSetForeground'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Graph_set.c:384: undefined reference to `XFillRectangle'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Graph_set.c:386: undefined reference to `XSetBackground'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Graph_set.c:387: undefined reference to `XSetForeground'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Graph_set.c:389: undefined reference to `XClearWindow'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Graph_set.c:398: undefined reference to `XFlush'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Graph_set.c:350: undefined reference to `XCreateColormap'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Graph_set.c:356: undefined reference to `XQueryColors'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Graph_set.c:357: undefined reference to `XStoreColors'
> OBJ.i686-pc-linux-gnu/Graph_set.o: In function `find_truecolor_visual':
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Graph_set.c:112: undefined reference to `XGetVisualInfo'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Graph_set.c:128: undefined reference to `XFree'
> OBJ.i686-pc-linux-gnu/Graph_set.o: In function `use_window':
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Graph_set.c:144: undefined reference to `XSelectInput'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Graph_set.c:146: undefined reference to `XGetWindowAttributes'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Graph_set.c:150: undefined reference to `XScreenNumberOfScreen'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Graph_set.c:319: undefined reference to `XDisplayName'
> OBJ.i686-pc-linux-gnu/Line_width.o: In function `XD_Line_width':
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Line_width.c:9: undefined reference to `XChangeGC'
> OBJ.i686-pc-linux-gnu/Panel.o: In function `XD_Panel_delete':
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Panel.c:99: undefined reference to `XFreePixmap'
> OBJ.i686-pc-linux-gnu/Panel.o: In function `XD_Panel_restore':
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Panel.c:71: undefined reference to `XCopyArea'
> OBJ.i686-pc-linux-gnu/Panel.o: In function `XD_Panel_save':
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Panel.c:28: undefined reference to `XGetGeometry'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Panel.c:34: undefined reference to `XCreatePixmap'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Panel.c:35: undefined reference to `XCopyArea'
> OBJ.i686-pc-linux-gnu/Polydots.o: In function `XD_Polydots_rel':
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Polydots.c:41: undefined reference to `XDrawLines'
> OBJ.i686-pc-linux-gnu/Polydots.o: In function `XD_Polydots_abs':
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Polydots.c:17: undefined reference to `XDrawPoints'
> OBJ.i686-pc-linux-gnu/Polygon.o: In function `XD_Polygon_rel':
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Polygon.c:38: undefined reference to `XFillPolygon'
> OBJ.i686-pc-linux-gnu/Polygon.o: In function `XD_Polygon_abs':
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Polygon.c:20: undefined reference to `XFillPolygon'
> OBJ.i686-pc-linux-gnu/Polyline.o: In function `XD_Polyline_rel':
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Polyline.c:41: undefined reference to `XDrawLines'
> OBJ.i686-pc-linux-gnu/Polyline.o: In function `XD_Polyline_abs':
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Polyline.c:17: undefined reference to `XDrawLines'
> OBJ.i686-pc-linux-gnu/Raster.o: In function `XD_Raster_int':
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Raster.c:38: undefined reference to `XGetWindowAttributes'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Raster.c:43: undefined reference to `XCreateImage'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Raster.c:129: undefined reference to `XPutImage'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Raster.c:158: undefined reference to `XPutImage'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Raster.c:105: undefined reference to `XPutImage'
> OBJ.i686-pc-linux-gnu/Raster_RGB.o: In function `XD_RGB_raster':
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Raster_RGB.c:67: undefined reference to `XGetWindowAttributes'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Raster_RGB.c:69: undefined reference to `XCreateImage'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Raster_RGB.c:101: undefined reference to `XPutImage'
> OBJ.i686-pc-linux-gnu/Respond.o: In function `XD_Respond':
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Respond.c:7: undefined reference to `XClearWindow'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Respond.c:8: undefined reference to `XSync'
> OBJ.i686-pc-linux-gnu/Serve_Xevent.o: In function `set_busy':
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Serve_Xevent.c:373: undefined reference to `XDefineCursor'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Serve_Xevent.c:377: undefined reference to `XFlush'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Serve_Xevent.c:375: undefined reference to `XUndefineCursor'
> OBJ.i686-pc-linux-gnu/Serve_Xevent.o: In function `set_title_busy':
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Serve_Xevent.c:340: undefined reference to `XGetWMName'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Serve_Xevent.c:353: undefined reference to `XFree'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Serve_Xevent.c:364: undefined reference to `XSetWMName'
> OBJ.i686-pc-linux-gnu/Serve_Xevent.o: In function `service_xevent':
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Serve_Xevent.c:68: undefined reference to `XPending'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Serve_Xevent.c:71: undefined reference to `XNextEvent'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Serve_Xevent.c:81: undefined reference to `XInternAtom'
> OBJ.i686-pc-linux-gnu/Serve_Xevent.o: In function `handle_resize_event':
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Serve_Xevent.c:246: undefined reference to `XGetWindowAttributes'
> OBJ.i686-pc-linux-gnu/Serve_Xevent.o: In function `check_flush':
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Serve_Xevent.c:324: undefined reference to `XClearWindow'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Serve_Xevent.c:292: undefined reference to `XFreePixmap'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Serve_Xevent.c:293: undefined reference to `XCreatePixmap'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Serve_Xevent.c:294: undefined reference to `XGetGCValues'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Serve_Xevent.c:295: undefined reference to `XSetForeground'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Serve_Xevent.c:296: undefined reference to `XFillRectangle'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Serve_Xevent.c:297: undefined reference to `XSetForeground'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Serve_Xevent.c:298: undefined reference to `XSetWindowBackgroundPixmap'
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Serve_Xevent.c:299: undefined reference to `XClearWindow'
> OBJ.i686-pc-linux-gnu/Serve_Xevent.o: In function `get_xevent':
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Serve_Xevent.c:37: undefined reference to `XCheckWindowEvent'
> OBJ.i686-pc-linux-gnu/Work.o: In function `XD_Do_work':
> /usr/local/src/epk/grass-6.2.0beta3/display/drivers/XDRIVER/Work.c:27: undefined reference to `XNoOp'
> collect2: ld returned 1 exit status
> make: *** [/usr/local/src/epk/grass-6.2.0beta3/dist.i686-pc-linux-gnu/driver/XDRIVER] Error 1
> gcc -I/usr/local/src/epk/grass-6.2.0beta3/dist.i686-pc-linux-gnu/include -g -O2 -D__W98__ -DPACKAGE=\""grassmods"\" -I/usr/local/src/epk/grass-6.2.0beta3/dist.i686-pc-linux-gnu/include \
> -o OBJ.i686-pc-linux-gnu/start.o -c start.c
> start.c:39:21: error: process.h: No such file or directory
> start.c: In function ‘start_mon’:
> start.c:73: error: ‘_P_DETACH’ undeclared (first use in this function)
> start.c:73: error: (Each undeclared identifier is reported only once
> start.c:73: error: for each function it appears in.)
> make: *** [OBJ.i686-pc-linux-gnu/start.o] Error 1
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
You didn't have some X11 libraries or includes
