[GRASS-user] Working with MOLA data
Ivan Shmakov ivan at ivanshmakov.homeip.net
Tue Apr 3 13:03:26 EDT 2007
>>>>> "CG" == Carlos \"Guâno\" Grohmann <Carlos> writes:
 CG> Hello, I just re-read the article from Frigeri et al, 2004, about
 CG> using GRASS with Mars MOLA data.
 CG> http://www.igc.usp.br/pessoais/guano/temp/tgis_grass_planetary_geology.pdf
 CG> SO the way to work with this data is to create a LatLong Location,
 CG> with "sphere" custom ellipsoid? The IAU coordinate systems are not
 CG> yet included in GRASS?
	IIUC, GRASS support for cartographic projections is based on
	PROJ.4 [1].  Should any new projections become available in the
	latter, GRASS will support them automagically.
[1] http://www.remotesensing.org/proj/
