[GRASS-user] GRASS 32bit/64bit do not use all available CPUs
Ulrich Leopold
uleopold at science.uva.nl
Wed Apr 4 04:08:20 EDT 2007
I have been trying out a precompiled GRASS 6.2.1 64bit version on a
virtualised ubuntu edgy system (vmware) with 4 CPUs (no hyperthreading).
When I run GRASS the sprocess only uses 1 CPU instead of 4. I also checked
with the original precompiled GRASS version for edgy (6.0). It does the same.
I also checked with a 32bit single CPU machine and hyperthreading modus. Both
GRASS versions do the same here as well. They just use 1 CPU instead of 2.
When I use the programm stress --cpu 4 for the 64bit system and stress --cpu 2
for the 32bit system both systems show 100% usage of all available CPUs.
What is the error? Does GRASS have an option to specify use of multiple CPUs
at compilation? Or is there something else?
Best regards, Ulrich
