[GRASS-user] GRASS63cvs v.rast.stats reports zero for many CATs
Brandon M. Gabler
bgabler at email.arizona.edu
Sat Apr 7 13:16:21 EDT 2007
Thank you for the tips, Maciej,
On a hunch, prior to your email, I did re-try the exercise with a
shorter prefix (s16 instead of slope16), and this solved the problem.
I think column width may have been the problem. I had inspected the
values at those locations, and they had normal slopes (7, 6, or 9
degrees, etc.).
Curious problem, solved thanks to suggstions from the grasslist as
always!
Brandon
On Apr 7, 2007, at 5:24 AM, Maciej Sieczka wrote:
> Dylan Beaudette wrote:
>> On Friday 06 April 2007 13:36, Brandon M. Gabler wrote:
>>> Fellow GRASSers -
>>> I am using GRASS 6.3 cvs, the Kynge's build, and I have an issue
>>> using v.rast.stats on a raster of slope. Many (n>100) of my
>>> archaeological sites, which are all polygons, produced 9 columns of
>>> zeros for the slope stat calculations.
> Can you provide a GRASS location containing the data necessary to
> reproduce your problem, and the exact v.rats.stats command? Otherwise
> it's hard to say what could be the problem.
>>> The oddest part is that I successfully calculated elevation stats
>>> from a DEM raster using the same v.rast.stats command. The slope
>>> raster was produced directly from the DEM, so resolution, etc. are
>>> exactly the same.
> Is it possible that the slope raster has really small values at these
> locations, ie. with numbers after 10th decimal place? There is a note
> in the v.rast.stats (it's a shell script), line 165:
> #check if DBF driver used, in this case cut to 10 chars col names:
> Propably Markus (script author) can explain why this is necessary.
> Maciek
