[GRASS-user] shortest distance using cost between centroid/lines
Brandon M. Gabler
bgabler at email.arizona.edu
Sun Apr 8 17:22:21 EDT 2007
A problem with which I am currently working relates to the r.walk
feature, for calculating anisotropic movement cost between two
points, and v.distance, for calculating the shortest distance between
my archaeological sites (areas) and river drainages (represented as
lines). I could convert everything to raster data, if that improves
the ability to calculate what I am interested in, but that's a
different story, and not worth noting right now...what I need to do
has not been described by any of the available examples and
questions, or maybe I am still not comprehending how to do it
properly, but here is the issue:
I want to find the shortest distance between an archaeological site
and a drainage. I do NOT want to specify to which drainage one should
look from each site, because I want it to be the least cost to get to
a source of water. I suppose that technically I would not NEED
anisotropic modeling, because the trips would be round trip, but I
still would prefer to do this with anisotropic distances because down
the road I may want distances calculated from one site, to a
drainage, to a different site, and back to the original site (for
example, total shortest distance from a pueblo to a river to a grid
garden back to the pueblo).
Therefore, the requirement of r.walk and r.cost to specify start/stop
points is not good for me.
Obviously, first I need a cost surface. For ease of argument, I'm
going to stick with slope and only slope right now. So, I have these
data:
All_sites - vector, polygons of sites (I also have a point version of
this map, where the centroids of the areas were converted to a point
topology)
Drainages - vector, lines of drainages
DEM_16 - elevation at 16 foot resolution
Slope_16 - slope at 16 foot resolution (calculated from DEM)
Aspect_16 - aspect at 16 foot resolution (also calc. from DEM)
Once I have identified the closest drainage based on least-cost-
distance, I want to upload two columns to the All_sites db, one for
the distance, one for the drainage identified as closest - just like
v.distance allows.
r.drain does some of what I want, but not completely. I have been
staring at the manual pages and searching the archives for a while
now, and it really seems that everyone has specified start/stop
points in mind (all of the talk about Tobler's hiking function a few
months back, for example).
Chances are that I am making this more complicated than necessary,
but I hoped there could be some sort of solution. If specifying a
destination is really the way I have to go, I can convert my drainage
lines into points, and just find the shortest distance to one of
those points via a cost surface. But again, I still don't know how to
let GRASS decide which of 2 lines, points, etc. are closer (via a
cost surface) and then have it give me that least-cost distance.
Any ideas?
Thanks much in advance,
Brandon
_______________________
Brandon M. Gabler
Doctoral Candidate
Department of Anthropology
University of Arizona
Tucson, AZ 85721
Phone: (520) 621-8455
Fax: (520) 621-2088
"Who? When? Whither? are the questions with which the archaeologist
challenges the refuse heaps, scattered potsherds, and broken shafts,
to tell of the builders who came and lived and went their way into
the templed past." -- Edgar Lee Hewett, in Pajarito Plateau and its
Ancient People, 1938
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20070408/9692214e/attachment.html
