[GRASS-user] Re: v.what.rast (large file)
Massimo Di Stefano
massimodisasha at yahoo.it
Wed Apr 11 09:07:02 EDT 2007
Hi Glynn
thanks for your suggestion,
i do not know the c code...
i must study it...
to walk around the problem
i used a bash script,
its sintax is like :
v.out.ascii | r.what > file_raster
then using awk
i extract the column of raster value from file_raster
and past it in the original vector file (ascii vector points )
then re-import the vector file using v.in.ascii -r (region of my raster)
Il giorno 11/apr/07, alle ore 14:22, Glynn Clements
<glynn at gclements.plus.com> ha scritto:
> Message: 2
> Date: Mon, 9 Apr 2007 09:48:15 +0100
> From: Glynn Clements <glynn at gclements.plus.com>
> Subject: Re: [GRASS-user] v.what.rast (large file)
> To: Massimo Di Stefano <massimodisasha at yahoo.it>
> Cc: grassuser at grass.itc.it, grass-dev at grass.itc.it
> Message-ID: <17945.64975.520050.289809 at cerise.gclements.plus.com>
> Content-Type: text/plain; charset=us-ascii
> Massimo Di Stefano wrote:
>> i've a large point vector file (ascii 160 mb)
>> can i divide my area in many subregion
>> and then patch the results ?
> The categories are modified in-place, so you can just run the command
> on each subregion; there's no need to "patch" anything.
> AFAICT, the problem is in the code which deletes duplicate categories:
> i = 1;
> while ( i < point_cnt ) {
> if ( cache[i].cat == cache[i-1].cat ) {
> cache[i-1].count++;
> for ( j = i; j < point_cnt - 1; j++ ) {
> cache[j].row = cache[j+1].row;
> cache[j].col = cache[j+1].col;
> cache[j].cat = cache[j+1].cat;
> cache[j].count = cache[j+1].count;
> point_cnt--;
> continue;
> i++;
> This is O(n^2), but thiscould be done in O(n). The problem is that
> it's shifting the remainder of the array down by one place at each
> step, when it could move each entry to its final destination in one
> go. E.g. (untested):
> i = j = 1;
> while ( i < point_cnt && cache[i].cat == cache[j-1].cat ) {
> cache[j-1].count++;
> i++;
> cache[j].row = cache[i].row;
> cache[j].col = cache[i].col;
> cache[j].cat = cache[i].cat;
> cache[j].count = cache[i].count;
> i++;
> j++;
> point_cnt = j;
