[GRASS-user] Error in r.in.gdal: CPLCalloc(): Out of
memory allocating for "EHdr/ESRI .hdr Labelled" driver
Patton, Eric
epatton at nrcan.gc.ca
Wed Apr 11 14:42:35 EDT 2007
Frank,
Thanks for the feedback. The error persists with gdalinfo -mm:
$ gdalinfo -mm 45_18_N_66_06_W_BACKSCATTER.flt
Driver: EHdr/ESRI .hdr Labelled
Size is 2641, 3721
Coordinate System is `'
Origin = (2531369.500000000000000,7366720.500000000000000)
Pixel Size = (1.000000000000000,-1.000000000000000)
Corner Coordinates:
Upper Left ( 2531369.500, 7366720.500)
Lower Left ( 2531369.500, 7362999.500)
Upper Right ( 2534010.500, 7366720.500)
Lower Right ( 2534010.500, 7362999.500)
Center ( 2532690.000, 7364860.000)
Band 1 Block=2641x1 Type=Byte, ColorInterp=Undefined
ERROR 2: CPLCalloc(): Out of memory allocating -329 bytes.
Aborted (core dumped)
Filing a bug in the gdal bugtracker.
~ Eric.
-----Original Message-----
From: Frank Warmerdam [mailto:warmerdam at pobox.com]
Sent: Wed 4/11/2007 3:54 PM
To: Patton, Eric
Cc: grassuser at grass.itc.it
Subject: Re: [GRASS-user] Error in r.in.gdal: CPLCalloc(): Out of memory allocating for "EHdr/ESRI .hdr Labelled" driver
Patton, Eric wrote:
> I'm trying to import a pile of Arc floating point binary rasters (.flt and .hdr extensions) with r.in.gdal:
> $ r.in.gdal input=45_18_N_66_06_W_BACKSCATTER.flt output=45_18_N_66_06_W -oe
> WARNING: Over-riding projection check.
> I'm using a fresh install of GDAL 1.4.1, along with a fresh 6.3 cvs update from today. I see that at 1m resolution, the output raster would be 9,827,161 cells in size - pretty big. Is this the source of the CPLCalloc error?
> Can anything be done as a workaround, i.e., using gdal tools to reduce the resolution of the output raster on the fly? I have 350 of these rasters to import.
Eric,
This isn't a big raster, so that's not the problem. Can you try
"gdalinfo -mm" on the same file? Negative allocation errors normally
mean a bug somewhere in the driver code. If gdalinfo -mm also has
a similar error, then file a bug against GDAL and ensure you include
the .flt header (the data itself should not be needed).
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
