[GRASS-user] NVIZ max res ppm = reboot!
Glynn Clements
glynn at gclements.plus.com
Tue Apr 17 17:03:28 EDT 2007
"Carlos \"Guâno\" Grohmann" wrote:
> > > yesterday, working with the last cvs, when I tryed to export a NVIZ
> > > view with max.res. ppm, my machine rebooted! it worked fine in 6.2
> > > deb.
> > Try:
> > export GRASS_NO_GLX_PBUFFERS=1
> > export GRASS_NO_GLX_PIXMAPS=1
> > Unfortunately, a number of OpenGL drivers claim to support pBuffers
> > and/or GLX Pixmaps then crash (sometimes quite horribly) if you
> > actually try to use them.
> nope. rebooted again.
In that case, you'll just have avoid using the "max res PPM" option.
OpenGL crashes are mostly beyond our control.
