[GRASS-user] v.digit cannot update table
Seb
spluque at gmail.com
Sat Apr 21 15:33:50 EDT 2007
In GRASS CVS, I'm encountering problems digitizing into a vector with the
following:
v.digit -n map=newvect bg="d.vect coastline"
Clicking on the settings button -> table tab -> "create table" tells me
that a new empty map has been created. I then proceed with the "digitize
new boundary" button and create a polygon. When right-clicking to close
the line I'm asked about what encoding to use (I leave it as utf-8 which
which is my locale) and then "submit", I receive the following error:
---<---------------cut here---------------start-------------->---
DBMI-DBF driver error:
SQL parser error:
in statement:
update newvect set where cat = 1
Error in db_execute_immediate()
WARNING: Cannot update table
---<---------------cut here---------------end---------------->---
and on exit:
Building topology ...
1 primitives registered
Building areas: 100%
0 areas built
0 isles built
Attaching islands:
Attaching centroids: 100%
Topology was built.
Number of nodes : 2
Number of primitives: 1
Number of points : 0
Number of lines : 0
Number of boundaries: 1
Number of centroids : 0
Number of areas : 0
Number of isles : 0
Number of incorrect boundaries : 1
Any ideas what might be wrong? Thanks.
Cheers,
Seb
