[GRASS-user] Problem with displaing map
Jarosław Jasiewicz
jarekj at amu.edu.pl
Mon Apr 23 03:58:21 EDT 2007
Hamish napisał(a):
> Jarekj Jasiewicz wrote:
>> on cvs updated on 22.04, 20.00
>> problem with displaying raster map both in monitor and map display
>> nviz also crashes wen I try to display raster
>> on d.rast map=mapa error message: Segmentation fault (core dumped)
>> On grass 6.2.1 (stable) all work fine
> what about "r.info mapa" ?
> are all other raster maps in the same mapset ok? or bad too?
> what if you create a new raster map with:
> r.mapcalc one=1
> or
> r.mapcalc newmap=mapa
> are they ok?
> Hamish
I update cvs today morning, now all seems OK - maybe unreported error
ocured during compilation or something similar, I don't know...
If problem will occur again I will report
Jarek
