[GRASS-user] v.digit cannot update table
Maciej Sieczka tutey at o2.pl
Tue Apr 24 02:56:16 EDT 2007
Seb wrote:
> On Sat, 21 Apr 2007 14:33:50 -0500,
> Seb <spluque at gmail.com> wrote:
>> Hi, In GRASS CVS, I'm encountering problems digitizing into a vector
>> with the following:
>> v.digit -n map=newvect bg="d.vect coastline"
>> Clicking on the settings button -> table tab -> "create table" tells me
>> that a new empty map has been created.  I then proceed with the
>> "digitize new boundary" button and create a polygon.  When
>> right-clicking to close the line I'm asked about what encoding to use (I
>> leave it as utf-8 which which is my locale) and then "submit", I receive
>> the following error:
> The cause of this error was that the table needs to have more than the
> 'cat' column.  I was simply creating the table without adding an extra
> column because I don't need any attributes.
The problem has been already reported 8 months ago:
http://intevation.de/rt/webrt?serial_num=5127
Maciek
