[GRASS-user] r.reclass and g.remove: another issue
Jarekj Jasiewicz
jarekj at amu.edu.pl
Fri Apr 27 01:10:40 EDT 2007
Glynn Clements napisał(a):
> Glynn Clements wrote:
>>> The problem is beacause:
>>> in:
>>> ~/spearfish60/nowe/cell_misc/abc
>>> exist file reclased_to with "cdf at nowe"
>>> if reclased_to will be removed manually base map can be removed without
>>> problem. Unfortunatly I don't how to fix it
>> The first g.remove should have removed the entry from the reclassed_to
>> file; I'll look into why it didn't.
> The code was unconditionally appending @mapset to the name, looking
> for e.g. cdf at nowe@nowe in the reclass_to file.
> Fixed in CVS.
thanks
