[GRASS-user] problem installing perl mapscript for grass 6.2.1-3 on ubuntu Feisty Fawn
Michaël Rabotin michaelrabotin at gmail.com
Fri Apr 27 11:02:21 EDT 2007
Hi everybody,
to run a perl script I need to install a per module: perl-mapscript. I'm on
Ubuntu  Feisty Fawn with grass 6.2.1-3.
 When I use synaptic to install perl-mapscript, it said that I need to
remove grass to install perl-mapscript.
If I remove grass and install perl-mapscript, and I want to reinstall grass,
it said that I need to remove perl-mapscript. I can't have the both in my pc
Is anybody know how to do to install perl-mapscript to use with grass
PS: I need perl-mapscript because I found a perl script which use the
Douglas-Peucker algorithm for line simplification (this script use ESRI
shapefile in input and output; I don't know if the using of ESRI shapefile
is the reason to need perl-mapscript module)
Thanks for your response
Mick
M.
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20070427/0dd38bc5/attachment.html
