[GRASS-user] 32 bit OS .. 64 bit OS
gary lists at lazygranch.com
Fri Aug 3 04:04:17 EDT 2007
On the AMD64, 64 bit code uses the extra internal registers. Some math
operations run faster, though this has only been benchmarked under X64,
not linux.
I never had a grass run take more than about 2Gbytes of DRAM. Isn't
there a hard limit on the memory used by grass? There is an option
during the compilation process for large files, so I assume the memory
allocation isn't completely dynamic.
Glynn Clements wrote:
> RAVI KUMAR wrote:
>> GRASS GIS on 64 bit OS, is good news, but is the
>> progress
>> only in the 64 bit GRASS version ??
>> What are the differences (advantages) for shifting to
>> the 64 Bit OS. I do not have ready access to any 64
>> bit OS system. The latest (is there any) 32 bit OS
>> GRASS,
>> is this not equivalent to 64 bit GRASS ??
> The only differences between running GRASS on a 32- or 64-bit OS are
> those provided by the OS, e.g. the ability to use more than 4GiB of
> memory for a single process, or the ability to read files larger than
> 2GiB using ANSI stdio functions.
