[GRASS-dev] Re: [GRASS-user] 32 bit OS .. 64 bit OS
Moritz Lennert
mlennert at club.worldonline.be
Fri Aug 3 13:20:41 EDT 2007
On 03/08/07 19:05, Brad Douglas wrote:
> On Fri, 2007-08-03 at 15:57 +0200, Maciej Sieczka wrote:
>> Markus Neteler wrote:
>>> Maciej Sieczka wrote on 08/03/2007 12:21 PM:
>>>> Ravi, are you referring to the fact that there is no generic 32bit
>>>> binary GRASS package on GRASS website, but only 64bit?
>>> If so, I don't know how to generate 32bit binaries on a (pure) 64bit
>>> machine as the GRASS server is. A way out would be that a community
>>> member auto-generates 32bit Linux binaries which I then auto-fetch
>>> every week.
>> Hi
>> After some reading I must say I'm to ignorant in this regard and won't
>> help much. If anybody is willing to take on this, I found 2 usefull
>> resources: "building 32bit app on 64bit system" [1] and "How to build
>> 32-bit Wine on a 64-bit (x86-64) system" [2]. The latter is about Wine,
>> but it gives detailed instructions for several main distributions,
>> which could help.
>> [1]http://www.linuxquestions.org/questions/showthread.php?t=570955
>> [2]http://wiki.winehq.org/WineOn64bit
> export CFLAGS="-m32..."
> However, I fail to see the usefulness of 32bit GRASS on 64bit systems.
The question was whether Markus could use his 64bit server to
cross-compile binaries for 32bit systems or whether someone with a 32bit
system would have to do it.
Moritz
