[GRASS-user] r.le Problem
Paolo Cavallini
cavallini at faunalia.it
Sun Aug 5 13:24:25 EDT 2007
have you tried r.li? if it can solve your problem, it will probably do
faster and in a more flexible way.
pc
Martin_Besta ha scritto:
> Hi,
> I have some problem with r.le.pixel. When I am trying to use this modul,
> with my raster layer as background and another raster layer as sampling area
> (ca. 207 squares, 300x300m). Resolution of both layers is 1m, the program
> after few minutes computing prints error: "G_calloc: out of memory
> r.le.pixel is working..."
>>From this time happend nothing more. I had take a look in System monitor and
> system memory is during calculation enough. Another module like r.le.pach
> does work correct with the same dataset.
> Thanks
> Martin
Paolo Cavallini, see: http://www.faunalia.it/pc
Desc: OpenPGP digital signature
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20070805/d41827af/signature.bin
