[GRASS-user] null values
    Glynn Clements
    glynn at gclements.plus.com
    Mon Aug  6 12:10:56 EDT 2007
goldneaa at onid.orst.edu wrote:
> Lets say I have a map with a range of -20, and 20.  I am able to
> create a legend that only shows -10,10.  But I want my map to only
> show values from -10,10.  Is there a way to make the areas that are
> above 10, or below -10 show up as white or null values on the display
> map.  I have been playing around with val. list in d.rast.  But I have
> not had much sucess in creating maps that take out my max and min
> outliers.  Any suggestions?
If the maps are integer-valued, use r.reclass to map the undesired
categories to null.
If the maps have floating-point values, use r.mapcalc instead.
While the r.mapcalc approach will work for integer values, it copies
the map data, while r.reclass only need to store the reclass rules.
