[GRASS-user] “Random read is not supported by OGR for this layer, cannot build support.”
    Frank Warmerdam
    warmerdam at pobox.com
    Mon Aug  6 15:59:32 EDT 2007
Spencer Fogg wrote:
> Hi, GRASS users! I am a novice, and have only been using this program
> for a couple of months now. I'm having a problem using GRASS with
> postgres for a project at work, and I was wondering if you guys could help.
> I'm working with shapefiles, and want to display them in GRASS. Some of
> these files are large enough to crash GRASS while cleaning, and even
> more take longer to draw and redraw than I'd like. To avoid this, I'm
> attempting to use v.external to connect to the files in a postGIS table,
> created using shp2pgsql. When I run v.external, however, I get a strange
> warning: "Random read is not supported by OGR for this layer, cannot
> build support." Then when I try to display the created vector layer,
> GRASS crashes.
Spencer,
On review of the OGR PostGIS driver I think this is a bug in the driver's
"TestCapabilities" method.  Are you in a position to rebuild your GDAL with
a patch?  I'd appreciate your filing a bug against GDAL/OGR for this issue,
and we can pursue the discussion there.
   http://trac.osgeo.org/gdal/
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
