[GRASS-user] xganim & underlying data?
Tue Aug 7 15:17:19 EDT 2007
M S wrote:
> In xganim, is it possible to use an underlying raster such as a DEM with an
> elevation colormap or vector contours?
Each frame has to be a GRASS raster map. If you want to use anything
else, you have to convert it.
