Michael Perdue wrote: > > Did you try using the full path to the color files? > > Sure did, but that functionality doesn't work in GRASS6.2.X. You can get the same result in 6.2 by redirecting stdin, e.g. r.colors mapname color=rules < /path/to/rules_file -- Glynn Clements <glynn at gclements.plus.com>
