[GRASS-user] clipping line data to a polygon
Hamish
hamish_nospam at yahoo.com
Fri Aug 17 01:21:34 EDT 2007
> Mark wrote:
> > Is the best way to clip data to use the v.overlay command with the
> > "and" operator?
> > it works great, but seems quite slow on larger datasets.
> > Additionally as an example, if i have topographic contour lines, and
> > i want to clip them to a polygon, and only want the topo line
> > attributes (elevation) outputted, is there a way to do this? Is
> > there another way to clip line data to within a polygon that might
> > be a bit faster?
Hamish:
> run v.select, then v.overlay. That way the intensive v.overlay
> operation only happens for relevant vector features. Then it will
> speed up hugely.
> I wonder if v.select functionality could be built into v.overlay as a
> preprocessing step?
(see Radim's doc/vector/TODO in the source code; maybe splitting long
boundaries helps too?)
Hamish
