[GRASS-user] v.generalize to smooth polygon boundaries ?
Wolf Bergenheim
wolf+grass at bergenheim.net
Wed Aug 29 08:18:23 EDT 2007
On 29.08.2007 21:42, temiz wrote:
> hello
> how can I use v.generalize to smooth polygon boundaries.
> As far as I see it is only used for lines not polygon boundaries
v.generalize works on lines, boundaries and areas. You can specify which
you want to generalize with the type= parameter. It defaults to any kind
of line. If you don't get good results, try to alter other parameters.
Unfortunately there are no good defaults which will work in all cases.
--Wolf
<:3 )---- Wolf Bergenheim ----( 8:>
