[GRASS-user] Re: Fwd: r.le Problem
Paolo Cavallini cavallini at faunalia.it
Thu Aug 30 05:17:10 EDT 2007
Hi Martin.
Never seen this. Leo, could you please check?
All the best.
pc
Martin Besta ha scritto:
> Sorry, my previous message was not complette...my e-mail client or I was
> wrong:)
> Hi Paolo,
> I have tried r.li <http://r.li> for Shannon index calculation...BUT...
> I wanted to set my rectangles from vector layer as a sampling areas,
> however, if I try in r.li.shannon to choose configutration file (made
> beforehand) I recieve this error message:
> Cannot make stat of
> /home/martin/.r.li/history//home/martin/.r.li/history/natura_clean
> configuration file
> Illegal filename. Character <#> not allowed.
> Can't open header file for [(#å·P#å·#A¿ in (null)]
> CHILD[pid = 6797]: unable to open (#å·P#å·#A¿ mask ... continue without!!!
> CHILD[pid = 6796]: unable to open (#å·P#å·#A¿ mask ... continue without!!!
> CHILD[pid = 6795]: unable to open (#å·P#å·#A¿ mask ... continue without!!!
> CHILD[pid = 6794]: unable to open (#å·P#å·#A¿ mask ... continue without!!!
> CHILD[pid = 6793]: unable to open (#å·P#å·#A¿ mask ... continue without!!!
> CHILD[pid = 6792]: unable to open (#å·P#å·#A¿ mask ... continue without!!!
> CHILD[pid = 6791]: unable to open (#å·P#å·#A¿ mask ... continue without!!!
> CHILD[pid = 6790]: unable to open (#å·P#å·#A¿ mask ... continue without!!!
> CHILD[pid = 6789]: unable to open (#å·P#å·#A¿ mask ... continue without!!!
> CHILD[pid = 6788]: unable to open (#å·P#å·#A¿ mask ... continue without!!!
> I tried various vector layer to check this problem, but it is happening
> every time.
> I think, the problem is about the configutration file.
> My procedure was:
> First set up the raster file as sampling frame, than vector as overlayed
> layer.
> Second set up the sampling frame as Whole map, than set up the sampling
> areas as Select areas from overlayed vector layer.
> Finally Save settings. This file I have choosen as configuration file
> for r.li.shannon (as test with r.li.simpson too, but with the same effect) .
> Could you check my technique for errors?
> I need necessarily this index for my work. However r.le.pixel even
> r.li.shannon seems to couldn't work with my data sets.
> Thanks
> Martin
> 2007/8/7, Paolo Cavallini < cavallini at faunalia.it
> <mailto:cavallini at faunalia.it>>:
>     Hi Martin.
>     Is this http://grass.itc.it/grass63/manuals/html63_user/r.li.html
>     <http://grass.itc.it/grass63/manuals/html63_user/r.li.html> not
>     enough?
>     I have something, but I'm afraid you will not understand it, as it is in
>     Italian.
>     However, the behaviour of r.li <http://r.li> is rather similar to
>     r.le, so you should
>     not have major problems.
>     All the best.
>     pc
>     martin.besta at googlemail.com <mailto:martin.besta at googlemail.com> ha
>     scritto:
>     > Hi Paolo,
>     > thank for your advice. I will try it. Now  I am using Grass 6.2.1
>     but module r.li <http://r.li> seems to be very important for my
>     work. Can I have some more detailed dokumentation to r.li
>     <http://r.li> (somethigs like for r.le)? Reference Manual for Grass
>     6.3. I already have.
>     > Thanks
>     > Martin
>     > Paolo Cavallini wrote:
>     >> have you tried r.li <http://r.li>? if it can solve your problem,
>     it will probably do
>     >> faster and in a more flexible way.
>     >> pc
>     >> Martin_Besta ha scritto:
>     >>> Hi,
>     >>> I have some problem with r.le.pixel. When I am trying to use this
>     modul,
>     >>> with my raster layer as background and another raster layer as
>     sampling
>     >>> area
>     >>> (ca. 207 squares, 300x300m). Resolution of both layers is 1m, the
>     program
>     >>> after few minutes computing prints error: "G_calloc: out of memory
>     >>> r.le.pixel is working..."
>     >>> >From this time happend nothing more. I had take a look in System
>     monitor
>     > and
>     >>> system memory is during calculation enough. Another module like
>     r.le.pach
>     >>> does work correct with the same dataset.
>     >>> Thanks
>     >>> Martin
>     >> Paolo Cavallini, see: http://www.faunalia.it/pc
>     >> _______________________________________________
>     >> grassuser mailing list
>     >> grassuser at grass.itc.it <mailto:grassuser at grass.itc.it>
>     >> http://grass.itc.it/mailman/listinfo/grassuser
>     > Quoted from:
>     http://www.nabble.com/r.le-Problem-tf4220376.html#a12006425
>     <http://www.nabble.com/r.le-Problem-tf4220376.html#a12006425>
Desc: OpenPGP digital signature
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20070830/524bd5e5/signature.bin
