[GRASS-user] grass.bat script for Cygwin GRASS 6.2.2-1
Luigi Ponti
lponti at infinito.it
Fri Aug 31 03:30:45 EDT 2007
Hamish wrote:
> Luigi Ponti wrote:
>> Installation instructions at
>> <http://grass.itc.it/grass62/binary/mswindows/> say that "there's no
>> grass.bat script", but (no matter what I try) there is no way for me to
>> start grass with the recommended cygwin_grass.bat. It just works fine
>> if there is an X server already started from a previous grass.bat run.
>> Below you find the error log I have obtained via the following command
>> cygwin_grass.bat > c:\cygwin\all_out.txt 2>&1
>> Starting GRASS ...
>> Application initialization failed: this isn't a Tk applicationcouldn't
>> connect to display "localhost:0"
>> Error in startup script: dynamic loading is not currently available on
>> this system
>> while executing
>> "load /usr/local/lib/tk8.4/../libtk8.4.a Tk"
> Did you modify the bash line to run startx, launching X at startup?
> bash --login -i -c startx
Yes, I did. Here is my cygwin_grass.bat file:
@echo off
C:
chdir C:\cygwin\bin
set GRASS_AUTOSTART=1
If I run just the last line at the command prompt:
bash --login -i -c startx > c:\cygwin\all_out.txt 2>&1
I get the following all_out.txt:
Welcome to the XWin X Server
Vendor: The Cygwin/X Project
Release: 6.8.99.901-4
Contact: cygwin-xfree at cygwin.com
XWin was started with the following command line:
X :0 -multiwindow -clipboard
_XSERVTransmkdir: Owner of /tmp/.X11-unix should be set to root
winValidateArgs - g_iNumScreens: 1 iMaxConsecutiveScreen: 1
(II) XF86Config is not supported
(II) See http://x.cygwin.com/docs/faq/cygwin-x-faq.html for more
information
winDetectSupportedEngines - Windows NT/2000/XP
winDetectSupportedEngines - DirectDraw installed
winDetectSupportedEngines - DirectDraw4 installed
winDetectSupportedEngines - Returning, supported engines 00000007
winSetEngine - Multi Window or Rootless => ShadowGDI
winAdjustVideoModeShadowGDI - Using Windows display depth of 32 bits
per pixel
winAllocateFBShadowGDI - Creating DIB with width: 1024 height: 768
depth: 32
winFinishScreenInitFB - Masks: 00ff0000 0000ff00 000000ff
winInitVisualsShadowGDI - Masks 00ff0000 0000ff00 000000ff BPRGB 8 d
24 bpp 32
null screen fn ReparentWindow
null screen fn RestackWindow
InitQueue - Calling pthread_mutex_init
InitQueue - pthread_mutex_init returned
InitQueue - Calling pthread_cond_init
InitQueue - pthread_cond_init returned
winInitMultiWindowWM - Hello
winInitMultiWindowWM - Calling pthread_mutex_lock ()
winMultiWindowXMsgProc - Hello
winMultiWindowXMsgProc - Calling pthread_mutex_lock ()
MIT-SHM extension disabled due to lack of kernel support
XFree86-Bigfont extension local-client optimization disabled due to
lack of shared memory support in the kernel
(--) Setting autorepeat to delay=500, rate=31
(--) winConfigKeyboard - Layout: "00000410" (00000410)
(--) Using preset keyboard for "Italian" (410), type "4"
Rules = "xorg" Model = "pc105" Layout = "it" Variant = "(null)"
Options = "(null)"
The XKEYBOARD keymap compiler (xkbcomp) reports:
> Warning: Type "ONE_LEVEL" has 1 levels, but <RALT> has 2
symbols
> Ignoring extra symbols
Errors from xkbcomp are not fatal to the X server
(--) 3 mouse buttons found
Could not init font path element /usr/X11R6/lib/X11/fonts/TTF/,
removing from list!
Could not init font path element /usr/X11R6/lib/X11/fonts/Type1/,
removing from list!
Could not init font path element /usr/X11R6/lib/X11/fonts/CID/,
removing from list!
Could not init font path element /usr/X11R6/lib/X11/fonts/100dpi/,
removing from list!
winPointerWarpCursor - Discarding first warp: 512 384
winInitMultiWindowWM - pthread_mutex_lock () returned.
winProcEstablishConnection - Hello
And X does start (it is an X terminal and if I type grass62 and hit
return, GRASS starts just fine). But if I manually run at promt:
the next thing I see is the GRASS startup message
Cleaning up temporary files.....
Starting GRASS ...
And no X runs. GRASS starts in text mode but then it tries to load a GUI
and off course this fails.
Hope I provided some useful info. Thanks in advance,
Luigi
P.S. I also added the following at the and of .bashrc
# Start GRASS
if [ -n "$DISPLAY" ] && [ -n "$GRASS_AUTOSTART" ] ; then
unset GRASS_AUTOSTART
exec grass62
fi
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20070831/853d7f6a/attachment.html
