[GRASS-user] problem whit "map is 3D"
Benjamin Ducke
benjamin.ducke at ufg.uni-kiel.de
Mon Dec 3 04:35:15 EST 2007
As I understand, v.edit is currently pretty much 2D only.
As far as I am concerned, it would be great
if v.edit could do some _basic_ 3D manipulations.
I'd love to have the ability to swap coordinate
values freely between axes and the attribute table,
so that I can turn a X/Y/Z map into X/Y+HEIGHT or
vice versa.
Another great feature would be the ability to rotate
points around a freely-definable axis in 3D space
(maybe better to add this to v.transform, though?).
If I had those, I could un-install my CAD applications
right now ;)
I know that there is probably no-one with enough
free time on their hands to implement these things
right now, but maybe we could just think how to best
design them and who knows, sooner or later some-one
might get around to implementing them.
Benjamin
Martin Landa wrote:
> Hi,
> 2007/12/2, Ondrej Kozlovský <ondrej.kozlo at azet.sk>:
>> A have a problem what command
>> I can use to make a zero
>> in "map is 3D"???
>> (see attachemnt picture)
> for converting 3d vector map to 2d (i.e. remove z coordinates), you
> can use v.in/out.ascii magic:
> $ v.out.ascii input=d3 format=standard | v.in.ascii output=d2 format=standard
> Martin
> BTW: Is there more elegant way how to do the conversion, maybe a new
> tool for v.edit??
>> thank
>> Ondrej Kozlovský
>> 5. roc(ník Geodézia a Kartografia - kataster nehnutel(ností a pozemkové
>> úpravy
>> Slovenská technická univerzita v Bratislave
>> Stavebná fakulta
>> Radlinského 11
>> 813 68 Bratislava
>> www.svf.stuba.sk
>> Tato zpráva byla vytvor(ena pr(evratným poštovním klientem Opery:
>> http://www.opera.com/mail/
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
Benjamin Ducke, M.A.
Archäoinformatik
(Archaeoinformation Science)
Institut für Ur- und Frühgeschichte
(Inst. of Prehistoric and Historic Archaeology)
Christian-Albrechts-Universität zu Kiel
Johanna-Mestorf-Straße 2-6
D 24098 Kiel
Germany
Tel.: ++49 (0)431 880-3378 / -3379
Fax : ++49 (0)431 880-7300
www.uni-kiel.de/ufg
