[GRASS-user] LRS and Documentation
Markus Neteler neteler at fbk.eu
Thu Dec 6 12:42:20 EST 2007
Hi Luca,
maybe you need to run v.net on the network first, see
its man page for instructions to add missing nodes.
Markus
On Thu, Dec 06, 2007 at 06:39:56PM +0100, Luca Casagrande wrote:
> Hello everybody,
> i am doing the tutorial from:
> http://grass.itc.it/grass63/manuals/html63_user/v.lrs.create.html
> and all seem fine, until I run the last command (v.lrs.create).
> v.lrs.create --o busroute points=busstops out=route_lrs err=lrs_error
> lidcol=lid pidcol=lid rstable=route_lrs thresh=50
> This is the error:
> WARNING: Not enough points (0) attached to the line (cat 1), line skip.
> WARNING: Not enough points (0) attached to the line (cat 16), line skip.
> After that out_lines is empty and lrs_error show the whole network.
> Am I missing something?
> Thank you
> Luca
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Markus Neteler  <neteler fbk eu>  http://mpa.fbk.eu/markus/
FBK-irst -  Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18        -       38050 Povo (Trento), Italy
New book:                         http://www.grassbook.org/
