[GRASS-user] How to best access hundreds of orthophotos --
	mapserver as WMS server?
    Rainer M Krug
    Rainer.grass at krugs.de
    Fri Dec 14 02:22:11 EST 2007
Hi
I have hundreds, probably thousands, of orthophotos which I would like
to access as easy as possible. They are in MrSid format, but I will
convert them to geotiff.
My problem is that it is sometimes quite difficult to find the one
covering the region I am working in and it involves quite some trial and
error to get the right one (which is time intensive and annoying...).
I thought about setting up mapserver as a WMS server, but I didn't
manage (might have to spend some m ore time on that). What I would like
to know:
1) Is mapserver as WMS server the best solution or is there a more
effective one?
2) If mapserver (WMS server) is the way to go - can somebody give me an
example .map file which is achieving that?
3) the whole layer is obviously in several single tiles - can mapserver
handle this as a single layer or do I( have to do something special?
Sorry for the slightly oftopic questions - but 1) should be ontopic.
Thanks
Rainer
