[GRASS-user] Re: How to best access hundreds of orthophotos --
mapserver as WMS server?
Ivan Shmakov
oneingray at gmail.com
Sun Dec 16 21:18:40 EST 2007
>>>>> Hamish <hamish_b at yahoo.com> writes:
>>> an idea: write a little script to make a vector coversheet index.
>>> I am not sure, but I think v.patch does not clean topology so
>>> overlap may be ok.
> Ivan:
>> Wouldn't it be better to save non-overlapping parts and an
>> intersection as separate polygons? A separate attribute will be
>> needed to store the list of IDs of the covering images.
> see overlapping polygon example at:
> http://grass.ibiblio.org/screenshots/vector.php
Thanks, I'll check it.
>>> # store current region
>>> g.region save=old_region
>> It makes me wonder each time I see such a fragile construct like
>> this, will GRASS ever support overriding the region
>> ``temporarily''? (E. g., via a command line argument, or an
>> environment variable.)
> there is, see GRASS_REGION and WIND_OVERRIDE shell variables:
> http://grass.ibiblio.org/grass63/manuals/html63_user/variables.html
This is exactly what I've asked for. Thanks!
> but saving & restoring g.region isn't need for this task, it is just
> being nice leaving the place as you found it. The script is not
> dependent on the starting region. And I fail to see how that's
> fragile?
Consider this script being interrupted in the middle (say, by
the user hitting ^C.) Will the region be restored?
> No more fragile than trusting anything else written to the disk.
It looks to me that the following will be much more robust:
export WIND_OVERRIDE=tmp_region
# no need to store current region
# g.region save=old_region
g.region rast="$MAP"
# no need to reset to original region, either
# g.region old_region
>> And, could there be something a bit more clever than storing the
>> region of the image as a vector feature?
> the user can get as complicated as they like..
>> A combination of downsampling, `r.mapcalc' (to obtain the fill mask),
>> and `r.contour', may be?
> r.contour is not so good for ortho photos or high resolution land use
> map with many small areas. But again, up to the user....
Actually, I meant using `r.contour' on the downsampled fill
mask. (Meanwhile, I've silently switched to my own needs, which
are about the satellite data.)
