[GRASS-user] Re: How to best access hundreds of orthophotos --
mapserver as WMS server?
Ivan Shmakov
oneingray at gmail.com
Sun Dec 16 21:28:06 EST 2007
>>>>> Dylan Beaudette <dylan.beaudette at gmail.com> writes:
>>> an idea: write a little script to make a vector coversheet index.
>>> maybe output that with the HTMLMAP driver for an interactive web brower
>>> pull up.
>> And, could there be something a bit more clever than storing the
>> region of the image as a vector feature? A combination of
>> downsampling, `r.mapcalc' (to obtain the fill mask), and
>> `r.contour', may be?
> Hi,
> What you are asking for is starting to sound like a Mapserver driven
> WMS.
Actually, I'm seeking for a some kind of cataloguing solution
for GRASS. However, setting up Mapserver is also on my TODO
list.
> Here is how I have dealt with this problem in the past:
> 5. create a very simple mapfile pointing to the tile index
> shapefile. I will work up an example and post it back
TIA.
> 6. fill in appropriate WMS metadata into the mapfile
> 7. use r.in.wms to import imagery into GRASS
> -or-
> 7. once GDAL 1.5 is released it will be possible to an r.in.gdal and
> point it to an XML file defining a WMS resource. A mini-script might
> be able to construct the XML file on the fly...
> Unfortunately you will still have to manage the images that are
> imported into GRASS with GRASS commands, unless you constantly
> overwrite a temporary set of files by always using the same names and
> the --o flag.
> Once you have mapserver setup WMS is quite fast and flexible - it
> will even project the data on the fly to other coordinate systems.
Yes, I know. (Though I hadn't succeed in getting it to show me
any rasters last time I've tried it; the software packages were
from Debian etch, if that matters.)
