[GRASS-user] Working with a large number
 of maps
    Gerald Nelson
    gnelson at uiuc.edu
    Wed Dec 19 08:50:08 EST 2007
When you get this all working, please post a description of the final outcome in the grass wiki.
Thanks,
Jerry
---- Original message ----
>Date: Wed, 19 Dec 2007 15:16:10 +0200
>From: Craig Leat <craig at pid.co.za>
>Subject: Re: [GRASS-user] Working with a large number of maps
>To: Glynn Clements <glynn at gclements.plus.com>
>Cc: grass-user at lists.osgeo.org
>Glynn Clements wrote:
>> Craig Leat wrote:
>>> I have 139 high resolution images, which I need to use as a background map
>>> for some digitizing work.
>> How do the individual maps relate to the overall region?
>> If they are (approximately) tiles, I would suggest using a
>> hierarchical approach, patching groups of adjacent tiles into larger
>> tiles, then patching the larger tiles together, so that each r.patch
>> operation has relatively few maps, and the earlier stages have
>> relatively small regions.
>> The total time taken by r.patch is roughly proportional to the total
>> number of cells in the region multiplied by the number of input maps,
>> so the combination of a large region and a large number of maps will
>> be slow.
>Thanks for the advice Glynn. The images are tiles and the filenames
>follow a regular pattern, so I am able to patch blocks together quite
>easily with a simple script. I included lots of echos in the script and
>now I even have verbose messages ;-)
>The script is running right now and making good progress...
>Craig
>_______________________________________________
>grass-user mailing list
>http://lists.osgeo.org/mailman/listinfo/grass-user
Gerald Nelson
Professor, Dept. of Agricultural and Consumer Economics
University of Illinois, Urbana-Champaign
office: 217-333-6465
cell: 217-390-7888
315 Mumford Hall
1301 W. Gregory
Urbana, IL 61801
