[GRASS-user] Creating a ground water from a vector files of
contours?
Moskovitz, Bob
Bob.Moskovitz at conservation.ca.gov
Mon Feb 5 15:50:40 EST 2007
Hello Grassusers,
Like the subject line says, I need help creating a ground water map using a vector file of contours. The ground water file came from a E00 file that was read into Grass using v.in.e00. I am currently running v.surf.rst which is taking a long time to run. Are there other ways to do this problem?
Thanks in advance,
Bob
Bob Moskovitz
Seismic Hazards Zonation Program
California Geological Survey
http://gmw.consrv.ca.gov/shmp
CONFIDENTIALITY NOTICE: This communication is intended only for the use of the individual or entity to which it is addressed. This message contains information from the State of California, California Geological Survey, which may be privileged, confidential and exempt from disclosure under applicable law, including the Electronic Communications Privacy Act. If the reader of this communication is not the intended recipient, you are hereby notified that any dissemination, distribution, or copying of this communication is strictly prohibited.
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20070205/c0e0bbbd/attachment.html
