[GRASS-user] v.segment, v.lrs.create
Markus Neteler
neteler at itc.it
Tue Feb 6 07:49:16 EST 2007
Thomas Drüssler wrote on 02/06/2007 09:07 AM:
> Hello everybody,
> i'm using grass now for about 3 months now, and i still have some problems with management of vectors and tables.
> now i'm trying to create transects with two meter segments. i established the transects along several hightlines with
> v.in.ascii 3d lines and v.in.ascii 3d points, but now i don't succeed in establishing the two meter segments.
Do you have points and lines as two separate vector maps and want to
combine them? Then v.patch and v.clean will be needed.
> what is the easiest way (v.segment?, v.lrs.create?, other?)
With an existing line (or several), I simply do:
v.split transects out=transects_split length=2
It inserts vertices every 2 map units (meters in my case).
Markus
> and how do i use the command, concerning tables and input data?
> thanks for your reply
> thomas
