[GRASS-user] r.mapcalc median filters entire map instead of only null values
Patton, Eric epatton at nrcan.gc.ca
Tue Feb 6 12:02:22 EST 2007
It's ok, Glynn tested the script out and it worked for him, so I can't
explain what was happening. My script even works for me now. User error,
I guess ;)
I didn't know r.fillnulls was a script, as I've never used it before.
Maybe I could take a look at using other interpolation methods as you
suggest.
~ Eric.
Eric Patton
email: epatton at nrcan.gc.ca
> -----Original Message-----
> From: Hamish [mailto:hamish_nospam at yahoo.com]
> Sent: Tuesday, February 06, 2007 4:58 AM
> To: Patton, Eric
> Cc: grassuser at grass.itc.it
> Subject: Re: [GRASS-user] r.mapcalc median filters entire map
> Patton, Eric wrote:
> > I'm trying to use r.neighbors and r.mapcalc in a script to
> fill holes
> > in a raster where there are null values. A temporary raster
> is created
> > with r.neighbors that contains a 3x3 median-interpolated surface of
> > the primary DEM. r.mapcalc should only use the value in
> this temporary
> > raster where a null value occurs in the primary DEM.
> perhaps modify/extend the r.fillnulls script? A flag to use
> an alternate interpolation technique might be nice.
> Hamish
