[GRASS-user] Re: Xganim errors in WinGRASS
Hamish
hamish_nospam at yahoo.com
Tue Feb 6 18:25:26 EST 2007
> yuri bay wrote:
> > I am trying to use the 'xganim' function (in WinGRASS) to animate a series
> > of vectors (converted from shapefiles) but has encountered the following
> > attached errors.
Another (Cywgin required) solution:
d.slide.show -v across=1 down=1
Glynn:
> Clearly, this component isn't included in the WinGRASS binary
> packages. xganim requires Motif (it's currently the only module which
> does);
> Cygwin provides a package for LessTif (which should work), so there
> isn't any fundamental reason why xganim can't be provided on Cygwin;
> it just requires whoever builds the Cygwin packages to install LessTif
> and use --with-motif when configuring GRASS.
(general call for packagers)
It would sure be nice if someone produced a GRASS 6.2.1 Cygwin binary.
Currently the most up-to-date binary available for the Cygwin version
is 6.1-cvs April 17, 2006. i.e. there is still no stable GRASS 6.2
available for Windows users -- what's the problem? shared libs?
Hamish
