[GRASS-user] combining tiles
maning sambale
emmanuel.sambale at gmail.com
Wed Feb 7 11:13:16 EST 2007
> Either this is a very common problem, or you were reading my
> mind. I've been trying to get 19 maps coloured properly, and I'd
> realized that none of the automatic settings were going to work
> because of the -9999 values skewing all the schemes. I hadn't yet
> figured out how to change those values to NULLs. I have exported my
> tiles to ESRI ascii grids, and the -9999 values don't appear to have
> influenced the subsequent analysis in Maxent. But it was getting very
> tedious hand-editing the colour tables.
You don't have to hand-edit all color tables for each map. Just edit
a rules file for on map then run:
#r.colors - Creates/Modifies the color table associated with a raster map layer.
r.colors map=your_map_that_has_skewed_colortable color=a_rules_file
#then
r.colors map=your_other_maps_with_skewed_colortable
rast=your_map_that_has_corrected_colortable
hope it helps.
Maning
| __.-._ |"Ohhh. Great warrior. Wars not make one great." -Yoda |
| '-._"7' |"Freedom is still the most radical idea of all" -N.Branden|
| /'.-c |Linux registered user #402901, http://counter.li.org/ |
| | /T |http://esambale.wikispaces.com|
| _)_/LI |http://www.geocities.com/esambale/philbiodivmap/philbirds.html |
