ODP: [GRASS-user] MOLA data elevation problem
Glynn Clements
glynn at gclements.plus.com
Thu Feb 8 05:46:21 EST 2007
Maciej Sieczka wrote:
> > There is in r.in.bin a -s flag(high bit means negative value) but when i used it, effect was the same.
> That's because (after the manual) "The -s flag is used for importing
> signed one byte data (range -128 - 127)."
> It would be very useful to have it extended to support 2 and 4 byte data.
That should be easy enough; I'll commit the following patch once I've
tested it.
--- raster/r.in.bin/main.c 18 Nov 2006 14:45:26 -0000 2.9
+++ raster/r.in.bin/main.c 8 Feb 2007 10:43:07 -0000
@@ -501,12 +501,18 @@
/* Import 2 byte Short */
if (swap)
SwabShort(&x_s[col]);
- cell[col] = (CELL) x_s[col] ;
+ if (sflag)
+ cell[col] = (CELL) (signed short) x_s[col] ;
+ else
+ cell[col] = (CELL) (unsigned short) x_s[col] ;
} else {
/* Import 4 byte Int */
if (swap)
SwabLong(&x_i[col]);
- cell[col] = (CELL) x_i[col] ;
+ if (sflag)
+ cell[col] = (CELL) (signed int) x_i[col] ;
+ else
+ cell[col] = (CELL) (unsigned int) x_i[col] ;
if(parm.anull->answer) {
if(flag.f->answer) {
